| Message |
thatoneothekid13, The factory provided no front wheel camber adjustment in the design of the z32. That said, about 8 years ago I had the same issue with inside tire wear, and tracked the issue down to settled springs on all 4 corners. At that time Nissan OEM springs cost more than aftermarket springs (1 inch lower), front camber shims with longer bolts, a rear top link infinitely adjustable, and new adjustable shocks front and rear altogether. I purchased the lot from Concept Z through Coz (his name). I can't recall the name of the individual products, but it was a cure that solved my tire wear issues. Yes, the car rides more firmly than stock at the shocks' lowest settings, but it was a good tradeoff in my estimation.
